Popping/Marble sound coming from front right suspension
Old 12-28-2023, 04:53 AM
Jag117's Avatar
Default Popping/Marble sound coming from front right suspension
Hello all, somewhat an odd query
For several months now I've had a popping sound (sounds similar to a marble or solid tapping sound) coming from the front right-hand side of my car, specifically, it can be heard clearly from inside the cabin (probably at a 30-degree angle looking down from horizontal eye line).
Usually, the precursor for the sound is when the front right wheel is under load, so accelerating, turning on a sloped driveway etc. Numerous times I've taken off my wheel and examined, only to come up with nothing (at least to my eyes nothing looks too out of the ordinary), I've slowly started to replace ageing components such as the sway bar bushing and links in eliminating the culprit. My Jag mechanic suggests might be the suspension washer in the engine bay (it felt quite firm and tight last time I checked, not sure if anyone has had experience with an issue like that). Am at a loss, I've attached a photo of the car parked in the middle of the sound occurring for reference
Old 12-28-2023, 04:15 PM
countyjag's Avatar
History would suggest that the lower shock absorber bushing would be a good place to start. Unhelpfully, when you have the car jacked up to remove the wheel, the weight of the suspension takes up the slack, but these are a common wear item and fairly simple to replace.
Old 01-09-2024, 06:25 PM
JPerrin's Avatar
Everything you’ve stated points directly to a bad wheel bearing
auriga
17
08-15-2022 05:11 PM
afrimpong
02-11-2020 12:50 PM
davidcalgary
05-20-2013 10:37 AM
p3x935
08-12-2010 11:10 PM
Striker27
08-12-2010 03:36 PM
Quick Reply: Popping/Marble sound coming from front right suspension
