Axle U Joint question
I have an outboard u joint on left side that is shot. Wondering if I can just replace u joint or do I need to pull axle half shaft to do that and so maybe just replace whole half shaft/joints with used one? Do I need to worry about the other side u joints or both sides bearings? 134K miles.
Received 12,739 Likes
Jaguar lists the U-joint as NLA (No Longer Available), and they don't list the bearings as available separately. But I think I recall that the U-joints are a common size and can be replaced. You might try a google search for 1997 Jaguar U-joint. The differential was made by GKN and it's likely that the axles were also.
The Jaguar part number for the U-joint is JLM1388 and forum sponsor SNG Barratt lists them as available, and the other forum sponsors may also have them. A google or eBay search will turn up other options such as this (I have no experience with this seller):
Jaguar Saloon GKN U-Joint Euro Port Parts
The axles are the same on the XJ40s and X300s, and the U-joints are the same on the XJ40, XJS, X300, X100 and X308, and possibly others.
Cheers,
Don
The following 3 users liked this post by Don B:
The following 4 users liked this post by Grant Francis:
The bearings are not expensive and they're not difficult to replace. Here are some photos of the job:
Rear Wheel Bearings Part 1 of 4
Rear Wheel Bearings Part 2 of 4
Rear Wheel Bearings Part 3 of 4
Rear Wheel Bearings Part 4 of 4
You'll also be halfway to having the diff output shaft out, and replacing the bearing and collar are also worth doing:
Differential Output Shaft Bearings Part 1 of 2
Differential Output Shaft Bearings Part 2 of 2
Cheers,
Don
The following 4 users liked this post by Don B:
The following 3 users liked this post by aholbro1:
