Why does the US-spec side-fender Jaguar-badge have wires going into it?
For US-spec cars that have the little side-fender badge in place of turn-signals, why are there wires going into it? Do they do anything? Is this just the wiring for side-turn signals if one would want to equip the car with them?
It has been a long time since I did mine, but I think it was the right side that had the connector in place, so it was plug and play to install the side light "repeater" or "side marker" on that side.
I had to wire the left side "repeater" to the turn signal in the bumper.
Remove the wheel well liner and run the wires to the turn signal, replace the liner and all looks stock.
Easy job, all you need is about 3 feet of wire, the correct plug, and a meter or test light to let you know which wires running to the turn signal you need to tap.
Most vendors will send you the plugs with the lights and bulbs if you ask for them.
A few threads on the subject, you will find more if you search:
https://www.jaguarforums.com/forum/x...cators-108786/
https://www.jaguarforums.com/forum/x...signal-131578/
https://www.jaguarforums.com/forum/x...s-xk8s-140631/
Vector
vdpnyc (02-19-2017)
