X308 side marker turn signal?
Old Nov 20, 2014 | 07:21 PM
homerj40's Avatar
Default X308 side marker turn signal?
Has anyone ever seen (or done) a conversion for the side marker badge (behind the front wheel wells) to be used as a turn signal - like on the newer Jettas, Hondas, etc.??? I was looking at something like these (but you would have to cut the body panel to recess the housings):
Pair Side Marker Smoke White Lamp for Honda 02 05 Civic EP3 02 06 Integra RSX US | eBay
Any thoughts or experiences???
Thanks,
Darren
Old Nov 21, 2014 | 01:13 AM
XKRacer's Avatar
You can buy the proper items..... On XKs the wiring is half there connected to the back of the badge not sure if the same applies on XJs...... Easy to do...
Old Nov 21, 2014 | 04:56 AM
andrew lowe's Avatar
Thanks,
Darren
If you want clear repeater lenses , with a little bit of fettling , you can use the boot ( trunk ) lights.
May be cheaper than importing the correct amber ones from the UK / Europe.
Old Nov 21, 2014 | 08:14 AM
Doug's Avatar
I'm betting that an X300 signal/repeater will drop right in....
Direction Indicator Side Repeater Lamp - Parts For XJ Series from (V)720125 to (V)812255 (X300) | Jaguar Heritage Parts UK
These were used on all X300s regardless of market. Should be very easy to find some good used ones. They'll be amber, though.
Old Nov 21, 2014 | 08:18 AM
Doug's Avatar
I just checked....same part number for the repeater lamp, X300 and X308
https://www.parts.com/index.cfm?fuse...0-%20Liter-GAS
Old Nov 21, 2014 | 01:11 PM
homerj40's Avatar
Default Euro side markers
Thanks for the link Doug! So, it looks like the Euro models had OE side markers. I'm hoping that there might be a wiring clip hidden in the body panel. (?)
THANKS AGAIN!
(I'll post pics when I get them in.)
Old Nov 21, 2014 | 01:32 PM
homerj40's Avatar
Ok, so I found these on eBay:
2 1995 97 Jaguar XJ6 VDP Front Side Marker Light Turn Signal Amber Blinker | eBay
Hoping that there are existing wires in the body panel. If not, will splicing these onto the front signals affect amp load electronically? Sometimes it will cause the blinker to not function properly?????
Thanks for your advice and feedback.
Old Nov 21, 2014 | 03:11 PM
Reggie's Dad's Avatar
I did the same modifications to my 02 VDP. Tyed into the front signal wiring with no flasher issues. Brandon
Old Nov 21, 2014 | 04:13 PM
homerj40's Avatar
Default Fender cutting?
Thanks "Dad"
Did you have any issues cutting through the fender? Like secondary panels or paint chipping? I plan on taping the area over and drilling opposing corners, then jig saw to the alternate corners. Obviously, I will start smaller and file out to a tight fit.
Thanks for the reply!
Old Nov 21, 2014 | 07:29 PM
Vector's Avatar
Thanks "Dad"
Did you have any issues cutting through the fender? Like secondary panels or paint chipping? I plan on taping the area over and drilling opposing corners, then jig saw to the alternate corners. Obviously, I will start smaller and file out to a tight fit.Thanks for the reply!
You don't have to cut anything, just pop out the Leaper and pop in the marker light, they both fit the same cut out in the fender, the right side is already wired, the wire is clipped to the back of the Leaper, you will have to wire the left side to the front turn signal.
I bought my side marker assemblies from a "breaker" in England, complete with bulbs and wiring connectors.
It's about a two hour job for a novice, you have to remove the left wheel and wheel arch liner to run the wiring on the left side.
Vector
Old Nov 21, 2014 | 11:48 PM
homerj40's Avatar
That's awesome. I was worried about having to cut the fender. There's a lot of tight traffic in LA and it will help to have indicators amidship.
Thanks again for the info! Cheers,
Darren
Old Nov 23, 2014 | 11:39 AM
smtguy's Avatar
Thumbs up
I did the same as Vector on my XJR.
The X300 sidemarkers are correct and fit the recess in the fender. As Vector says, the wiring including the connector is already there on the right side, making them plug and play. The left side you will have to run some wire to the front turn signal after removing the left wheel and inner fender liner.
Note that you will need the connector going to the back of the sidemarker on the left side, so try to get that included when you buy them. No holes to drill or wires to cut, just use IDCs to connect to the turn signal wires. No electrical issues, they work great, and I think provide an element of safety when lane changing.
Old Nov 23, 2014 | 04:00 PM
vincent661983's Avatar
Search my profile as I posted my side marker retrofit
Old Nov 24, 2014 | 02:55 AM
XKRacer's Avatar
A useful bit of information...... The interior footwell lights of an XK (X100) are the same as the the XJ side repeaters.... and they are clear!
Old Nov 24, 2014 | 12:11 PM
RonaldP's Avatar
Go to this web site and follow the wiring diagram, there are no components to purchase. This is a great site for lighting information.
Daniel Stern Lighting Consultancy and Supply
Old Nov 24, 2014 | 12:25 PM
Vector's Avatar
That's awesome. I was worried about having to cut the fender. There's a lot of tight traffic in LA and it will help to have indicators amidship. Thanks again for the info! Cheers,
Darren
The "Thanks" button is located on the lower right portion of all posts. Click it when the info posted helps you out.
Vector
Old Dec 4, 2015 | 12:37 AM
Platinum XJR's Avatar
Default Trunk lights
The trunk lights work great.
I like that the trunk lights match my clear turn signal / marker lenses.
The X300 repeaters work too if you like amber.
Old Dec 4, 2015 | 08:32 AM
luc's Avatar
luc
I hope that I'm wrong but those front calipers don't look real but rather like fake Chinese calipers cover. Pleas tell me that I'm wrong
Old Dec 5, 2015 | 12:51 AM
You are wrong.
Old Dec 5, 2015 | 10:10 AM
luc's Avatar
luc
Feel much better thank you. So wich calipers are they? Stock floating calipers painted red?
