Locating Ground wire for Cruise Control set switch
Old 06-06-2012, 01:18 AM
tylerwerrin's Avatar
Default Locating Ground wire for Cruise Control set switch
Hi guys,
i'm trying to retrofit and troubleshoot my cruise control setup in my 84 XJ6. I'm trying to figure out if my cruise set switch is properly grounded at the mom"ent.
I have found the black/pink wire which goes to the cruise control button, but i cannot locate the ground wire for this switch. There is a "double" ground "butterfly" ground loop that looks like it grounds the blinkers & washer stalks, but I can't be sure if the ground wire for the set switch is part of this.
Can anyone help?
Thanks!
Old 06-06-2012, 07:35 PM
anyone? should it be coming out of the stalk?
Old 06-06-2012, 08:46 PM
I will have to dig up the electrical guides tomorrow. They are at work. Hopefully it will help. Are there any in the sticky section?
Old 06-06-2012, 08:50 PM
the guide i have (from the cathouse) just shows that the ground wire is black, and it comes from the switch -- locating it in real life is the challenge!
Forcedair1
05-14-2023 03:28 PM
tberg
09-07-2015 07:32 AM
philwarner
09-05-2015 10:05 AM
laserguy
09-03-2015 02:02 PM
XFR_Gold
09-02-2015 12:24 PM
Quick Reply: Locating Ground wire for Cruise Control set switch
