Fitting tips for upper injector ring?
hi there,
I'm redoing all rubbers in and around my engine and need to fit some new upper rubber mounting rings found on all 12 injectors.
Is there a 'trick' to fit them? Mine don't budge any further than the center dent/rut in the injector itself... Too low to fit properly...
Any tips or tricks?
Cheers!
Btw. clean intakes fitted to a clean engine look great!
Any tips or tricks?
Cheers!
Done all twelve... Was easier if you have the right stuff...
1. some insulating tape
2. some liquid soap
3. some rubber gloves
Wrap the insulating tape around the upper section of the injector.
Smudge some soap around the inner surface of the rubber ring.
Push metal ring on and then carefully wedge the rubber ring up.
Done.
Not much force needed. And when dry, it won't come loose
Took 10 minutes last night
2. some liquid soap
Done.
Grant Francis (11-01-2014)
clubairth1
22
12-19-2022 07:08 PM
aholbro1
08-05-2021 05:02 AM
