Head Lights needed for 92 XJS
Hi all
Is there a specific place on this forum where one can look at parts offered for sale by members?
Anyway, I recently purchased a 92 XJS which has the Euro type headlights that barely show me anything.
I actually use the spot lights to see the road!!
One funny thing is that it has one headlight with only one double filament bulb, and the second headlight has two bulbs, one for low and the other for the high beam.
What I am looking for is either a complete set of the American type of head lights (two headlights each side) but provided these come using bulbs and not sealed beams.
Alternatively a pair of the two bulbed headlights that are in good condition.
This way I can put higher rated bulbs for clearer lighting.
Farouk
Farouk
look up towards the top of the site and you will see a blue toolbar. There is a marketplace drop down that lets you navigate to classifieds forums.
I have euro lights and they work fine, they should be a single bulb. The issue is mostly that the reflective coating inside comes off over time. Look inside, if its a red/orange color instead of shiny mirror, that would be the reason. I would investigate putting the right bulbs in though.
Check around ebay and craigslist for parts cars too though. Good luck finding something, personally i think the american lights ruin the look of the car and they look incredibly cheap.
there is a pair of euro lights on ebay right now for $300. You may find something cheaper on your side of the pond, most of the members here are from America. just watchout if you are putting LHD lights in a RHD car, they are usually aimed differently and the high beams can blind people
Challenger_7 (10-15-2014)
What baffles me is the fact that one of the headlights comes with 2 bulbs and is therefore more effective than the other side which comes with only one bulb.
I too prefer the Euro lights but was thinking of the US type just for clarity of the lights.
If you say they are good for you, I will investigate again.
Thanks again for your response.
Farouk
Can you possible post pics? I honestly have zero idea what you are talking about. With the two bulbs. The only ones I have ever seen, which are the same as mine, have a spot for a single dual filament bulb. I am wondering where you second bulb even goes.
Does the inside seem red/orange like I said?? It is possible to remove the lens and refinish the inside for a more reflective surface.
On the single bulb one, the bulb is fixed on the upper side of the light where the lens is more difficult to see through. It is a normal halogen type of bulb.
On the other, ther is one in the same position, and a second bulb on the lower part of the light.
The upper bulb is covered by a small round reflector covering the bulb, sort of twice the size of a Dollar coin, and in a way a bit similar to old Jaguar lights where they have the triangular metal stands to hold this round metal bit.
The bottom bulb is just stuck in there with no covers.
The reflector behind the upper one cannot be seen due to the structure of the glass.
On the lower part, yes the reflector is faded out towards orange.
If you are saying that this is the first time you hear about to bulbs, I wouldn't be surprised if this modification was carried out here?
Anyway, as you suggest, and also for me to understand these lights more, I will try to go to my garage tonight and strip them off.
I need to anyway as one of the lights is taking water into the lens.
Thanks for your follow up.
Farouk
Farouk
My lights have one bulb in them and when I switch my lights to daytime running, nothing happens with my headlights. It illuminates the front bumpers lights and rear running lights.
Yup........There are a few differences.
In the North America models they have 1 bulb, the park/side lights are amber and are in the indicator lights as you describe. Other markets they are white and are in the headlights. Also the light pattern, don't forget that RHD (UK) lights dip/low into the 'wrong' side, as into the oncoming traffic, for LHD cars.
I had a go at the car yesterday and managed to strip both headlights, and they both seem originals, but totally different in structure.
The one with 2 bulbs has "Made in France" on it.
Obviously the previous owner had this adapted for him because now there is nothing holding the headlight except for the chrome bezel !!
The bracket to hold the headlight from behind is missing and so are the 2 adjusting cables that adjust height and sideway.
They placed a piece of wood under the glass on the inside of the body to keep the light at the same level as the other one. Some mechanics are really terrible.
I will attach some photos for everyone's amusement, with some comments when I get home.
But the thing is both sides do not have a wide light coverage, and more like a spot. Is this how Euro Lights normally behave?
I can understand the dim light due to the fading of the reflector, but it should still be fairly wide spread??
I will be quite happy to reinstall a good set of Euro type lights if the coverage is good.
Comments are welcome.
Challenger_7 (10-17-2014)
The "L" marked Photos are for the left side and the R for the right.
I believe the L type are the correct one and leave it to you Gurus to figure out where did the R light come about
As you can see from the last photo, I am missing from the car the bracket that holds the light, and also missing the two adjusting cables.
Now to demonstrate what I mean about the lack of coverage, the following photos are of the low beam and hi beam lights, lit on my garage wall.
All contact are well and outside the enclosures the bulbs shine fine.
The one on the right is rated, I think, 65/100 W but cant really remember what I saw on it. But for sure I remember a high wattage.
On the left, there are 2 identical halogen bulbs of 55 W each, similar to the spot light bulbs.
Here we go.
Farouk
Here we go.
Farouk
