Power Door Locks Failing?
Old 11-08-2010, 09:42 PM
Vee's Avatar
Vee
Vee is online now
Received 1,519 Likes on 1,181 Posts
Default Power Door Locks Failing?
I have a 96 XJS AJ16. The power locks seem to work intermittently. If I press the remote, the locks lock/unlock about 50% of the time, first time only. If the locks don't lock/unlock automatically, it seems like they have gone to sleep. If I manually lock/unlock them with the key or from inside the car, they "wake up" and work fine, until left alone and I end up spinning the roulette wheel again.
Any idea what the cause may be? The passenger side door seems less reliable than the drivers side. So when I use the remote to lock the car, sometime the drivers side locks, but since the passengers side doesn't, the alarm starts chirping. When I manually actuate the passengers side lock, it seems to wake up and remember to work auto or manually.
What should I be looking at? Relays?
Old 11-09-2010, 08:40 AM
rama1200's Avatar
I have the same issue with my 94... additionally the mirrors seem "asleep" too... I bet is a loose connection somewhere, need for a good cleaning and some oil to free the mechanicims (sp?)
the other day i was driving and about after 30 minutes of driving the doors locked on their own....
Old 11-09-2010, 04:25 PM
Vee's Avatar
Vee
Vee is online now
I did oil the hell out of the actuator, but it still falls asleep. I also cleaned the connector with some electrical contact cleaner.
Before I greased it up, it was getting stuck, but now it seems to forget what to do...until it does, and then it works fine.
Very strange. I can't afford to spend time hunting down a connection. I was hoping it was indicative of a failing part, like a relay.
99xk8guy
05-12-2024 08:41 PM
99xk8guy
06-05-2023 06:28 AM
dsnyder586
04-04-2019 02:38 PM
XJsc-guy
11-23-2015 01:56 PM
AL NZ
09-04-2015 08:39 PM
Quick Reply: Power Door Locks Failing?
