What did you do to or buy for your XJ-S/XJS today?
orangeblossom (10-31-2014)
The following 2 users liked this post by Daim:
Lucielle (10-07-2022),
As for me, I ordered some LEDs for the panel lights on my XJ12. It would be nice to actually see the instruments at night
Wow Daim, are we looking at an extraordinarily clean part or is it painted silver? If its the former, please share your preferred cleaning supplies and technique.
#28
Started to rebuild the intakes today...:
More under: https://www.jaguarforums.com/forum/x...4/#post1085396
The following 4 users liked this post by Daim:
Greg in France (10-24-2014),
Lucielle (10-26-2021),
orangeblossom (10-31-2014),
paulyling (03-03-2015)
#30
#31
#32
I put 45psi in tires, topped it up with V power gas / jug fuel storage stabilizer, laid four plates of mothballs, two on engine/ one in cab/one trunk. disconnected battery and covered. No more got done when it started snowing. She has gone into hibernation for the winter and I will miss her terribly.
#33
I just received a bunch of little odds and ends from Terry's jag
New oem TWR power window and convertible top switches (the after market ones are garbage)
New sport mode switch for the transmission panel
All the OEM hardware to install my new undertray and new brake ducts (got the new brake ducts a month ago from Terry's Jag too)
The color filament that goes underneath the PDNR12
From Paul's Jaguar I got an allegedly "new and improved" bezel to hold down the switches I got from Terry's Jag
And from ebay I got a new wiring harness for the rear fog and back-up lamps. I ruined mine when I changed a bulb.
#34
Received 1,231 Likes
been there done that many times.
also wish i could show the inside of my manifolds and plenums, completly polished and smoothed out internally, called abrasive machining/extrude honed.
#35
#37
bought
case of oil filters
rotor for dist. ( found a great deal 28.00)
74C themostats (165 F) (have not installed them... I thought they would be good for after driving shut down with the 14" fan)
ordered
tire valve stem caps...
14" 2800 cfm fan
need
dist cap, gasket, air filter...
would like
2002 Jeep Grand Cherokee I6 coil pack...(x2) and make them work on the V12
case of oil filters
ordered
14" 2800 cfm fan
need
would like
#38
Pretty much finished removing the old interior from my '95 for the replacement interior. Some of the original oatmeal leather I can re-dye and reuse but most will be new, along with new carpets and wood (Carpathian elm burl?) and a slightly darker carpet, cinnamon replacing the original mink.
Then new paint and convertible top. My car is ice blue mica metallic, however, I was looking at a gorgeous '65 E Type this weekend that was opalescent silver blue (slightly darker than ice blue). So...will it be the original ice blue or opalescent silver blue?
#40
