2000 xk8 convertible door locks cycling
Old 09-01-2014, 07:22 AM
dnarraf's Avatar
Cool 2000 xk8 convertible door locks cycling
Got a problem with my latest acquisition. A 2000 XK8 Convertible with very low mileage. Have seen other threads on similar problems but not exactly the same.
When locking from outside with either the fob or the key, BOTH door locks cycle locked and unlocked 4 times and then the horn sounds. The locks work perfectly from inside the car. To stop horn unlock, which leaves the car locked until unlock is pressed again. Happens every time exactly the same. Can't work it out. Both windows lower and raise as doors are opened and closed as they should. Beats me! Could one faulty door latch micro switch cause this problem with both doors maybe? Or something else. Battery is tip top and no other problems. Any ideas anyone?
Old 09-01-2014, 10:09 AM
GGG is offline
Received 16,800 Likes on 12,169 Posts
Welcome to the forum dnarraf,
I've moved your question from XK/XKR 2006 onwards to XXK8/XKR 1996-2006 forum. Members here with the same model will be able to help.
99xk8guy
06-05-2023 06:28 AM
kelliott
05-31-2022 05:26 PM
XJsc-guy
11-23-2015 01:56 PM
brgjag
General Tech Help
17
09-09-2015 07:34 AM
obwoodie
09-03-2015 07:45 PM
Quick Reply: 2000 xk8 convertible door locks cycling
