1997 XK8 Transmission problem
Old 01-11-2013, 09:21 AM
noterman's Avatar
Default 1997 XK8 Transmission problem
I have a shift from 2nd to 3rd problem with my XK8. I have a post on here re that. I suspect I have a computer problem. My question is which numbers on the computer have to match up. I have 5 lines of numbers and letters. One of the lines is LJA 2401 AB. Is this the number I have to match up? I found a computer locally with LJA 2401 AA. I saw somewhere that the LJA 2401 AA will work but I am not sure. Is there a computer business that I can send my computer to have it checked out?
Thanks for your time. John
Old 01-11-2013, 10:22 AM
GGG is online now
Received 16,800 Likes on 12,169 Posts
That'll be the ECM number you're quoting?
A.f.a.i.k. it has to be the same suffix or later but will need to be programmed to the vehicle by a Jaguar dealer or an independent with the same diagnostic system facilities.
Before jumping to that costly possible solution, have you had the DTC error codes checked by someone with the facility to read transmission codes?
99xk8guy
06-05-2023 06:28 AM
toronadomike
08-07-2022 03:41 PM
XJsc-guy
09-25-2015 11:09 AM
laserguy
09-03-2015 02:02 PM
SouthernGypsy
09-03-2015 10:54 AM
Quick Reply: 1997 XK8 Transmission problem
