Headrest adjuster cable - clarification?
Old 03-01-2015, 02:33 AM
SteveGrr's Avatar
Default Headrest adjuster cable - clarification?
Hi all,
I've read the threads and watched the videos on taking a section out of the headrest adjustment cable and fixing the join with either a heat shrink sleeve or plumbing connector... but... I'm not clear why you wouldn't just shorten by cutting a piece off the end rather than in the middle of the cable?
The reason may become clear when I get the cover off the seat back but its not from the video or previous chat.
Old 03-01-2015, 05:53 AM
jamdmyers's Avatar
Yes it will, you either must pull the cable from the sleeve and cut it OR get a longer cable, but it's really not too hard. Go for it.
Old 03-01-2015, 07:39 AM
ccfulton's Avatar
Received 1,106 Likes on 763 Posts
The ends have a metal attachment for the motor and headrest mechanism so you have to take the tubing length out of the middle.
Old 03-01-2015, 07:52 AM
SteveGrr's Avatar
Thanks both. I will give it a go.
rothwell's Avatar
Received 1,252 Likes on 687 Posts
Originally Posted by SteveGrr
Hi all,
You have the right idea. Read here
SteveGrr (03-01-2015)
Old 03-04-2015, 08:31 AM
Jon89's Avatar
Received 4,276 Likes on 2,813 Posts
Point of clarification: You remove 12mm of the cable sheath, not the cable itself. Big difference. If you cut the cable itself, you'll be in world of hurt trying to repair the damage you've done....
jimforrest (uk)
02-28-2019 06:42 PM
adam699
10-13-2015 05:53 PM
tomkilner
10-09-2015 07:10 AM
10 XF Premium
10-02-2015 09:22 PM
Johncy2000
10-02-2015 01:05 AM
Quick Reply: Headrest adjuster cable - clarification?
