New Battery Didn't Help
Old 03-27-2015, 09:39 AM
riverrob's Avatar
Default New Battery Didn't Help
I got a new battery which when fully charged stopped the Poor Performance warning. However; something is draining the battery and after a week of not starting the car or driving it when I start it I get the warning again. Any ideas on what could be draining the battery? 1997 XK8.
Old 03-27-2015, 09:46 AM
test point's Avatar
Received 1,110 Likes on 932 Posts
First check that there is not a light on as that is the most common issue.
Are you leaving the key in the ignition? That keeps the security control module powered. Likewise, if the key slot cover does not close over the key slot with the key removed that has the same affect.
Beyond that pulling the negative battery cable and measuring current drain is next. More than 30ma after 30 minutes then you have to start pulling fuses to locate the offending circuit. Remember to take the bulb out of the trunk light when you start on that fuse box. Negative or positive doesn't matter. Just that the negative is easier to get to.
Old 03-27-2015, 09:48 AM
DaveInVA's Avatar
When I had that problem with my 97 it turned out to be the power amp for the stereo wasn't powering off like its supposed to and was draining the battery. An easy way to check is to pull the fuse for it in the trunk and see if the battery is still draining.
Dave
Old 03-29-2015, 07:38 AM
wolfpck1's Avatar
also look at the power antenna if it doesn't go down completely it will draw power trying to pull the antenna down the rest of the way even if everything is turned off .
Old 03-30-2015, 03:21 PM
fridge's Avatar
I have the same problem, does anyone out there have a fusebox diagram they could send over.
Thanks.....
Old 03-30-2015, 05:13 PM
GGG is offline
Received 16,799 Likes on 12,168 Posts
Thanks.....
John,
You've posted this question in XK8/XKR tech forum but your profile shows you have a 1996 XJ6. Exactly which vehicle are you troubleshooting?
Old 03-31-2015, 08:37 AM
test point's Avatar
Here is the chart for a '00 XK8/R which is, with minor exceptions, the same for the entire '96 - '06 run.
Can't help with the XJ6.
File Type: pdf
JarodL
03-07-2024 01:39 AM
99xk8guy
09-21-2019 07:34 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
mcdutch
09-04-2015 03:38 AM
philwarner
09-02-2015 11:45 AM
Quick Reply: New Battery Didn't Help
