Wayward steering and play in the rack (Video)
Old 11-24-2014, 04:45 PM
H20boy's Avatar
Received 1,144 Likes on 750 Posts
Default Wayward steering and play in the rack (Video)
Hey guys, I've never had to be concerned with the steering rack before, so this area of the car is new to me. I'm hoping to get some opinions of what I might need to do to fix this.
Symptoms: (1) rather quickly, the car has started to 'wander' on the road requiring constant wheel input to keep the car straight. It almost feels like tramlining, without the grooves in the pavement to cause it or when the control arm bushings are deteriorated. (2) After getting the front end up in the air, Left-Right movement of each wheel creates this rather significant noise and play, which appears along the inner tie rod, and thus the rack. I used a prybar to move the joints and bushings on the control arms and they're still really tight (even with weight of each corner supported) Take a look/listen at the videos, will ya?
Old 11-24-2014, 04:56 PM
RaceDiagnostics's Avatar
Looks like a worn rack if there is no corresponding movement of the steering wheel.
With the wheels on the ground, do you get this type of movement on the wheel?
Old 11-24-2014, 05:09 PM
H20boy's Avatar
Ok, I just checked what you asked, and there is absolutely zero play in the wheel itself.
Old 11-25-2014, 03:26 AM
OK, looks like you need to pull the boots back and check for play on the inner tie rod.
When I changed my rack one of the inner tie rods was still tight and there was a very small amount of play in the other, may have just been that the leaking fluid had thinned the grease in that one.
Old 02-12-2016, 10:44 PM
Ungn's Avatar
H20 Boy,
What was the solution to this?
I just finished my front suspension rebuild and noticed my rack acting just like your videos when I was tightening up all of the nuts.
Is it Inner Tie rods or the rack itself?
Old 02-13-2016, 08:14 AM
TexMurphy's Avatar
Can jump in and just ask a newbie jacking question? Is it safe to put jack stands in that location as in video? I didn't find that as approved location, so curious if this is a regularly used without issues spot I can use.
H20boy
07-23-2021 09:39 PM
rusty37
04-05-2020 07:40 PM
mrplow58
09-15-2015 09:58 PM
sogood
09-15-2015 07:35 AM
Richard_gib
09-12-2015 07:08 PM
Quick Reply: Wayward steering and play in the rack (Video)
