Rear bumper fittings
Just got round to removing my rear bumper to replace a broken mount (new mounts arrived today). When I was removing it I found that the brackets that hold the bumper sliding mounts were in an awful state (one had corroded right through and the other wasn't much better) so Does anyone know if the brackets are just bolt on and what they are called ? If not would drilling a couple of small holes through the bumper, into the body and securing with a few pop rivets hold it sufficiently ?
tberry6686 (06-23-2016)
As I only expect to have the car for another 2 years I may well try pop rivets.
As far as easy jobs spreading. Car has run out of MOT and needs a left hand upper O2 sensor, Octopus hose leaking so need to replace that as well. Got the hose out without much problem. The O2 sensor however is likely to need a new cat as well as it will not move no matter what I have tried so far (through from the footwell, spanner from above, soaking it for hours in penetrating fluid, spanner and hammer etc. Last throw of the dice for it is to try and cut it down short enough to get a normal sized socket and big breaker bar on it but the metal in the sensor is tough to cut with a hacksaw).
tberry6686 (08-21-2016)
If that is the mounts that come down from under the boot (ish) area and attach to the sides of the rear bumper then they are what I need to fashion (or something similar.
I have tried everything I can think of to move the O2 sensor now but it will not shift at all (even the sensor socket opens up and slips round without turning it so it looks like I will have to drop the cat out to get it (or replace the cat and both O2 sensors)
Chase6495
03-29-2016 09:07 AM
