Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
06 X-Type Sounding Phenominal!
Old Nov 20, 2010 | 06:45 PM
Trupain's Avatar
Default 06 X-Type Sounding Phenominal!
I Finally got the front portion of my sound system upgrade complete.
Originally I had planned on keeping a completely stock look but the factory
head unit just wouldn't comply with what I was looking for.
I have installed a Clarion VZ-709 DVD head unit, Soundstream Reference
Series Components in the front doors with the crossovers and Soundstream
TX2.500 AMP powering them from the trunk.
I went with the tarantula series amp purely for aesthetics The Piano black
finish and spider on the amp match the Crossovers perfectly.
Eventually I will be adding an RE audio Subwoofer powered by another
Soundstream amp. The amps and crossovers will be mounted on a carpeted
wall in the trunk effectively cutting the trunk space in half and isolating the
subwoofer from the storage area. Hopefully minimizing vibration and getting
the good sound where I want it.
Once its all done, and a bit warmer, I will get some pictures up so you all
can critique my work.
Old Nov 30, 2010 | 06:25 PM
sidewalkman's Avatar
Sounds awesome, summer is when I plan the replacement for mine. Did you start with the standard or Premium stock unit. And since yours is an 06, did you have functional Bluetooth?
Old Dec 1, 2010 | 06:43 AM
Trupain's Avatar
Mine did not have the premium sound package and the bluetooth module was not installed.
Old Dec 3, 2010 | 11:45 AM
How did you wire the amps? Did you use any of the stock wiring or all new. I've got a factory amp so I would have to add the inline transformers.
Old Jan 5, 2011 | 12:41 PM
Trupain's Avatar
I ran all new wiring. The only thing left factory is the pass through connector going from inside the cabin to the doors.
Thang Nguyen
Oct 12, 2015 01:25 AM
Davidvdm
Oct 7, 2015 03:18 PM
sawduster
Oct 3, 2015 12:10 PM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
simo5555
Sep 9, 2015 06:22 AM
