Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
98 XJR- Reverse wire for camera...
Old Dec 22, 2007 | 12:35 PM
sh500's Avatar
Default 98 XJR- Reverse wire for camera...
Hi all,
Does anyone know where the 'reverse signal wire' is in a 98 XJR?
I need to know where it is near the gearbox as the head unit that I have has a 'camera wire' that has to be connected to a reverse signal so the screen automatically switches to the 'rear camera' output when reverse gear is selected.
Many thanks.
Old Dec 23, 2007 | 01:16 AM
bigdreams05's Avatar
Default RE: 98 XJR- Reverse wire for camera...
Get it from the reverse lamp. You can use a small wire to run to the back like it were an amp wire, and whenever your car is put in reverse, the lamps turn on and therefore send the signal to your back-up unit.
Old Dec 23, 2007 | 04:50 AM
sh500's Avatar
I know I can get if from the reverse lamp, but that means running a wire through the whole length of the car.Can I not get it from some where near the auto box?
Old Dec 24, 2007 | 07:21 AM
and drill a hole through your firewall?
Old Jul 5, 2008 | 06:32 PM
Grim001's Avatar
I'm now looking for the same thing for my X type. I'll let you know if I get an answer
FrickenJag
Jun 16, 2025 02:15 PM
Rivguy
Nov 13, 2022 02:55 AM
Will P
Sep 19, 2018 08:36 AM
dstary
Sep 19, 2015 09:47 AM
jagent
Sep 12, 2015 09:10 AM
