Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
CAN-BUS Function for Stereo
Old Jul 30, 2019 | 07:34 AM
Souths1der's Avatar
Default CAN-BUS Function for Stereo
I finally got my hands on the wiring schematic for my 2016 X260. It looks like the Audio Head Unit feeds 4 inputs into the Amplifier: Right, Left, Chime, Navi-HFM. I will be using a Helix DSP. I have typically only been able to feed the DSP from the amplifier outputs. but it looks like I can grab the signal before the amplifier processes it with this new car. I should be able to just assign R/Chime/Navi-HFM to all the right speakers and L/Chime/Nave-HFM to all the left speakers.
Does anybody see a problem with the chain of thought? My worry is that the amplifier also has CAN + and - connections and I'm unsure what those are doing with regard to the amplifier and the sound. Any help would be appreciated.
Old Aug 17, 2019 | 07:55 AM
Souths1der's Avatar
Just to close the loop for anybody that may come across this thread..
Yes, I was able to pull sound directly from those inputs, however it was only at one level. I could not control the volume or left/right/fade, EQ, etc. I had to pull from the output side, and I had to pull Front Tweeters, Front Midranges, Front Woofers, and Subwoofer to get a full signal into my DSP. Everything sounds good,
markjord
Dec 22, 2021 04:46 AM
RobbyHughes
Mar 16, 2018 06:43 PM
Allan9
Nov 12, 2015 06:29 AM
2jag
Apr 12, 2011 08:45 AM
