Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Can I replace the head unit in my X350?
Old Dec 19, 2013 | 12:55 PM
anindyam's Avatar
Default Can I replace the head unit in my X350?
Can I replace the head unit in my X350 (2004 XJR) with something a bit more modern? My head unit also controls the AC, but there are separate buttons for my AC. I'm curious if they will continue to work without the factory head unit.
Old May 14, 2014 | 02:16 PM
x358x250's Avatar
I did a total replacement of my head unit in my 2008 XJ8L (358), but it had the head unit separate from the climate controls. I'm a bit confused by the way you describe your controls. If you have the nav screen, what I did will probably not work for you. As the 2008 and later got into fiber optics to the amps/speakers, I had to replace everything. You should be able to use much of what is there. I went with a Pioneer unit with dvd/cd/nav/sirius/bluetooth/backup camera. I will provide pics shortly. Good luck!
Old May 14, 2014 | 02:26 PM
x358x250's Avatar
Here are pics of my project in my 2008 (358).
Old May 14, 2014 | 04:35 PM
anindyam's Avatar
Nice job. Your before pic on the left looks nothing like mine. I have the touchscreen setup with Nav, CD player, radio etc. It also has screens to control AC. I am told by some of the shops around town that if I had to replace the until, I may not be able to control AC and other functions.
Old May 19, 2014 | 03:59 AM
veffremov's Avatar
With the nav unit you are out of luck, unless you are willing to strip everything and go back to the base unit like the picture above.
The nav unit controls the screen, climate and the audio HU. The audio HU controls the radio, cd, cd-changer, amp, phone and voice recognition - via the most obscure system ever invented.
Another complication with the nav setup is that you have "premium sound" which means your speakers are wired to an amp in the trunk, so you either have to put a separate amp in the trunk or bring the wires to the new HU in the front (not impossible, but annoying).
Old Nov 23, 2014 | 03:22 PM
DonsXJ8's Avatar
Can you share some more information on your install please. Where did you find the mounting kit?
SD96XJ6L
Jan 12, 2022 04:30 AM
Sprayall
May 30, 2021 08:13 AM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
XJsc-guy
Sep 2, 2015 11:43 AM
