Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
New Sub?
Old Jan 6, 2009 | 11:21 PM
blkholsuhn's Avatar
Default New Sub?
1998 XJ8, my subwoofer is missing, any ideas on where to find a new one, or replacement?
Old Feb 4, 2009 | 06:42 AM
Cerberus's Avatar
You talking about the rear deck one? I think you have to go OEM. I just looked into replacing mine - aside from the rear deck being a PITA to get out, the gas tank securing strap is right below the 6x9 and the cut-out in the rear deck metal is VERY small for reasons I can't figure out. All in all, it's probably EASIER to get an aftermarket sub in the trunk.
Old Feb 4, 2009 | 11:11 PM
phd12volt's Avatar
if you want to give me some measurements of the area you want to install it in, i can have a custom sub made for you. While it may not necessarily be the cheapest route, it can be done. I will need the mounting hole diameter, mounting depth, some pics in high resolution while making the measurements will help out immensly. Oh and let me know the impedence.
