Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
x-type audio question..
Old Jul 13, 2008 | 11:49 PM
playboiij's Avatar
Default x-type audio question..
whats up guys? im planning on installing a 10" or 12" ssa icon sub powered by a sundown sae-1000d amp and some new door speaker. i really dont want to get rid of the stock cd player (cause of the disk changer) but will i need to replace it w/ a aftermarket h/u? or will the stock cd player be power enough?
and what is the size of the door speakers? help is much appreciated.. thanks in advance..
Old Aug 19, 2008 | 12:23 PM
silverfox's Avatar
Default RE: x-type audio question..
I have a factory head unit and I'm pushing 2 12's and a rockford fosgate 500watt power series amp. It sounds great. The stoc k head unit pushes enough power. On the 02 x-type you can add an additional 2 6.5's on the rear deck. The cut outs are already there. Good luck with the install.
Old Aug 22, 2008 | 04:44 PM
aquill1's Avatar
The stock would be power enough for it...i know of some mb quart components that are low powered speakers (35w rms) and I'd check into something like that if I were you. That way they'll sound better than the stock speakers and better than a higher powered speaker set powered by your stock radio. Best bet is to power the 4 speakers but you'll be fine!
Paora
Feb 4, 2021 12:36 AM
Msteiner
May 16, 2016 12:19 AM
King Charles
Oct 16, 2015 01:25 AM
millertic
Sep 30, 2015 08:11 PM
