Engine swap XK8 97
Old Jun 6, 2025 | 05:35 AM
gardcycl's Avatar
Default Engine swap XK8 97
I found this thread but no responses which i found odd
"I have quite a dilemma, i bought an XK8 with a busted
engine(4.0liter)(some genious started the car after it was sitting for 3 years and busted the engine/block), so now i need a new engine.
I found a AJ-V8 from a Jaguar S-type 2001 4.0 liter, could any of you confirm that the engines are totally identical and swappable?
Are there any differences?(even slightest?) Will i need any additional parts for the swap? Any tips?"
I could not find any responses, so I though as i am in a similar pickle and no time to remove motor myself
What suggestions for a replacement motor do we have, 1997 - 2004 all the same? 4.0 lt or any later motors fit? what about ECU's swap? harness?
Who is best to complete an engine swap/rebuild between cairns and Adelaide? Who has the experience here
Old Jun 6, 2025 | 06:56 AM
JaagXKR's Avatar
They are not identical, from 1996 it is AJ26, since 1999 it is AJ27. Electronics are different: sensors, coils, throttle body, ECU, are not interchageable. I don't know if it's possible to swap only the block and the heads and keep all the other parts from the old engine..
Old Jun 14, 2025 | 06:52 PM
StuG's Avatar
You can contact Aaron at Classic & Prestige Auto Services in Geebung (07 3216 2054) or you can rely on the advice from a bunch of strangers on the internet. Your choice!
Flyboygus
Nov 3, 2023 08:25 AM
Thermo
US Mid Atlantic
Jul 18, 2023 08:33 AM
VicVegas84
Jun 28, 2021 07:37 PM
2859bar
Jan 6, 2021 06:06 PM
ifonly
UK & Eire
Sep 24, 2020 05:12 AM
