knock in motor
Old Aug 15, 2014 | 07:15 PM
hopeless jag owner's Avatar
Default knock in motor
my 88 xj40 has a terrible knock when u start it up which seems to be under the distributor and after a while it goes and i can alter the density of the knock by turning the steering wheel while the vehicle is stationary
help
hopeless
Old Aug 16, 2014 | 10:22 PM
yarpos's Avatar
here is a link to the xj40 specific forum area
click this XJ40 - Jaguar Forums - Jaguar Enthusiasts Forum
and post again, you may have more luck
Old Aug 16, 2014 | 10:33 PM
help
hopeless
As mentioned, BUT, check the tightness of that BIG bolt in the front of the crankshaft. They have a real habit of coming loose.You will need to jam the flywheel with a pry bar to achieve that tightness required.
I am not sure of the relationship of turning the steering, as the steer pump is gear driven from the aux shaft, that also drives the distributor, and is NOT a known issue.
Maybe a collapsed engine mount, but that is really clutching at straws.
Old Aug 17, 2014 | 06:52 PM
i should clarify and say the knock is not in the motor itself but someewhere around the bottom of the distributor or power steering pump
ui really appreciate the advice and i thank you
Old Aug 18, 2014 | 08:15 AM
OK.
Only thing under that area is the a/c compressor, and its myriad of mounting bolts (6+ from memory) and easy access (NOT) may be the source of the knock.
Old Aug 19, 2014 | 12:30 AM
aussie_ser3's Avatar
Its defiantly not the power steering pump its self? Especially if the knock is changed with movement of the steering wheel?
LnrB
Oct 13, 2015 12:45 AM
Newark Nj Gang
Oct 2, 2015 02:39 PM
inactualis
Oct 2, 2015 11:13 AM
JagBrian
Oct 1, 2015 12:52 AM
