XJ6 diff? upgrade
Old Nov 18, 2020 | 04:03 PM
slowy's Avatar
Default XJ6 diff? upgrade
Folks
I'm keen to understand whether one can upgrade an XJ6 differential's innards with new parts.
The diff is under my AC Cobra and was part of the initial owner's build, so I don't yet know exactly what variant it is but will be researching this soon.
I did get the diff worked on when I first bought the unfinished kit, my memory being a comment that the diff was out of a Mark 10 Jag but that doesn't seem right .
More importantly the gears weren't either too bad or too good and as a solid mount arrangement, I can hear back lash noise on acceleration / deacceleration, hence why I'd like to renew the mechanicals.
Is there a supplier of new replacement parts for these diffs or some other option.
I'd been keen for feedback on the options please.
Steve
Old Nov 19, 2020 | 01:42 AM
The Mekon's Avatar
Yes you can rebuild your existing diff. Parts are available through specialist Jag suppliers, or take a chance on another used diff. If your diff is from a Mk 10 then it either 3.54 or 3.77 ratio, which seemingly suits your gearbox.
All later diffs (1980's and later) are either 3.058 or 2.88 - perhaps a bit tall for you.
Old Nov 19, 2020 | 04:40 PM
slowy's Avatar
Thanks Mekon
And good pick up, I seem to recall its a 3.54 powerlok variant.
Runs through a TKO600 5 speed and the combo suits general road use well.
So you are saying new parts can be got, is that right?
Old Nov 19, 2020 | 08:02 PM
The Mekon's Avatar
Exchange diffs in the UK are available but expensive - like 2000 pounds!
I would check with Mike Roddy or V&A Spiteri if you are in Victoria.
deelli
XJ XJ12 ( X305 )
Sep 19, 2023 01:46 AM
slowy
General Tech Help
Dec 4, 2017 08:08 AM
sunchip
Aug 10, 2014 02:42 PM
colindavies
Jan 21, 2011 06:51 PM
jpskiller
XJ40 ( XJ81 )
Jun 30, 2009 04:25 PM
