Canada All Canadian members please post here...
RPM drop to zero
Old Oct 24, 2014 | 06:54 PM
ottotto's Avatar
Default RPM drop to zero
Hi,
got my 1974 XJ12 a few weeks ago and the engine was working fine so far. Today I started cold and had it run for a few minutes. After warming up all of a sudden the RPM dropped to zero. Restarted a few times and the RPM went up to about 2000 RPm and dropped again to zero, without any stuttering or similar.
Any idea what that might be? Probably no gas supply?
Would be great if someone had a similar problem and got it fixed.
Eric
Old Nov 9, 2014 | 10:09 AM
Quebecjag's Avatar
Is it very cold where you are? If yes, could be ice in the line. Just put a gas line bottle in the tank. Otherwise, I would start with a new gas filter.
Just my 2 cents
Guy
Old Nov 9, 2014 | 10:33 AM
Mikey's Avatar
Hi Eric-
I see you've also posted you question in the tech section for your car, I'm sure the experts will sort things out in short order.
Old Nov 10, 2014 | 09:45 AM
ottotto's Avatar
Just my 2 cents
Guy
Hi Guy,
thanks for the tip. I'm on Vancouver Island and it's rather wet than cold.
The Jaguar was sitting idle for four years when I got it and built up severe sediments of rust and other solids. I changed the gas filter again and blown out the gas line and some nasty stuff was coming out of the line. As I've to replace a lot of different parts due to deterioration I also changed the ignition switch, which was mentioned by other memebers. But I assume it was the stuff in the gas line that blocked the proper fuel supply.
Thanks for your recommendation.
Eric
Old Nov 10, 2014 | 09:34 PM
Quebecjag's Avatar
Originally Posted by ottotto
I changed the gas filter again and blown out the gas line and some nasty stuff was coming out of the line. But I assume it was the stuff in the gas line that blocked the proper fuel supply.
I would flush everything in the gas tank and, rince and repeat a few times !! You probable have a LOT of sh***t in the tank.
We had the same symptoms last week working on an old Farm tractor.
Guy
Dave1109971
Dec 15, 2015 06:16 PM
tomkilner
Oct 9, 2015 07:10 AM
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 06:43 PM
