Grease on My Carpet
Old Apr 4, 2011 | 12:50 PM
Car-Nut's Avatar
Question Grease on My Carpet
Ive got some grease on my carpet and its a lightish colour any tips on how to remove would be greatly received
Old Apr 4, 2011 | 01:51 PM
Innovative Detailing's Avatar
I haved used with success the following products....
1) Stoner "Tarminator"
2) Stoner "Xenit"
3) Meguiars Body Solvent
4) Meguairs APC+
5) IPA
Start with the APC+ first, spray directly on the stain and using a MF towel try to wick up some of the grease. Apply some APC+ on the towel directly and rub over the stain....if necessary spray a little more on the stain then wipe. If you need a little more scrubbing power, use a clean toothbrush to help. If the stain still remains, spot clean using the Stoner product which is a bit stronger, then wipe dry. Then clean the area with APC+ one last time, wipe dry and you should be good to go......
Old Apr 5, 2011 | 06:18 AM
Togwt's Avatar
+1 (Stoner’s Tarminator) or try an Ammonia solution; a tablespoon of clear household ammonia (3% solution) with 0.5 cup of distilled water.
bdboyle
Sep 16, 2019 05:58 PM
JimC64
Oct 11, 2015 09:04 PM
PinnacleWax
Detailing / Car care
Sep 25, 2015 12:46 PM
Nigels420G
Mark V - X 420G
Sep 25, 2015 10:10 AM
