Diesel variants - All models Visit here for discussions on diesel powerplants and the impressive torque / mpg figures achievable....
Oil mixing with water
Old Nov 22, 2016 | 02:11 PM
tymars's Avatar
Default Oil mixing with water
Hi! I am working on a Jaguar XF 2010 diesel and is being mixing oil and water, we drained oil but there were no sign of water from the engine oil, the car has been flushed several times course the oil is going to the cooling system, it has also overheated, we already have taken off cylinder heads to replace the gaskets but now we also suspect that may it be the seals in an oil cooler where there is an oil filter on the block behind the diesel pump? Can you please help course it little expensive to buy new oil cooler, or must i get new oil cooler seals? Your help can be very appreciated..
Old Nov 26, 2016 | 05:04 AM
As I write, your post has been up for 4 Days and had 250 Views but 0 Replies.
You could get more Views and some Replies in X250 forum. Let me know if you want it moved.
Old Jan 19, 2017 | 12:27 AM
Aussie Steve's Avatar
Hello tymars
I have same problem with my 2004 x type ... oil in water not water in oil.
did you find out what caused your problem?
Nice car by the way
Steve
