Diesel variants - All models Visit here for discussions on diesel powerplants and the impressive torque / mpg figures achievable....
Steering wheel and trip counter memory loss
Old May 29, 2015 | 04:23 PM
Valkyrie's Avatar
Default Steering wheel and trip counter memory loss
I have a problem with my 2006 s Type 2.7 diesel it's only done 46000mls and to look at has been well kept, I also have its service history and the garage is known to me as reputable.
When I switch off I get a pinging alarm and a msg that says apply foot and parking brake. When you do this the msg clears but the trip counter also zeros and the steering wheel drops to its lowest position.
It's happened twice in two days now, the first time it also cleared the radio code. Which I also had to reset!
Has anyone had a problem like this and if so what was the cause.
Would appreciate any help here as new to Jaguars.
Old May 30, 2015 | 06:53 AM
JagV8's Avatar
Sounds like a power fault. Failing battery, bad connection, that kind of thing.
Old May 30, 2015 | 08:03 AM
Valkyrie's Avatar
I've had a good look today and the battery appears to be the original factory fitted item. The difficulty in getting the battery strap bolts out to remove the battery also supports that it's been here a long time.
Bought a new one today, and just finished fitting and resetting all the brakes, windows, radio etc so I'll see how it goes from here. If I get a re occurance then I'll have to consider a bad connection.
If as I suspect the batt is original(with factory Jaguar sticker) it was ready for changing anyway, 9 years is excessive for a batt on any vehicle.
Thanks for the input it's appreciated.
Old May 31, 2015 | 09:44 AM
JagV8's Avatar
Hope it's that - yep those bolts sure rust solid, someone broke mine
Old Jun 2, 2015 | 03:17 PM
Valkyrie's Avatar
Having changed the battery and left things alone to see if I get a re occurrence, I have so far had no issues at all. Everything now seems to stay set exactly as I've put it.
Excellent advice thanks again.
H20boy
Dec 24, 2024 03:23 PM
99xk8guy
May 28, 2024 09:36 PM
PMKimpton
Aug 3, 2019 08:22 PM
Armor6
Sep 14, 2015 07:56 PM
AL NZ
Sep 4, 2015 08:39 PM
