E-Pace 2018 - Onwards
2021 e-pace battery removal
Old Oct 17, 2025 | 08:40 PM
nasomi's Avatar
Default 2021 e-pace battery removal
My wife's e-pace has had low battery for a bit. I'm going to replace it. Do I need to keep power to the posts while swapping? What happens i if i don't?
Also it looks like I will need to remove the cross member from the strut housings.
Has anyone tried this before?
Old Oct 18, 2025 | 01:58 AM
StuG's Avatar
Yes, the cross member needs to be removed. I purchased a 9v memory minder ($US10) from my local auto parts store and it plugs into the 12v socket in the console. Provides enough power to save the memory settings while changing the battery. The other option is to hook up a battery charger to the cables.
Old Oct 18, 2025 | 03:05 AM
nasomi's Avatar
I didn't know such a thing existed. Thanks for the heads up.
Old Oct 18, 2025 | 09:04 PM
2018XF25T's Avatar
Or you can just simply remove the battery. You need to update the time and date after you install a new one. My XF uses H7 AGM battery. Walmart, Costco and all auto part stores sells them.
Ftypeman1
Oct 23, 2024 04:28 PM
unicorn
Dec 23, 2022 02:14 AM
mrlooneytoon
Aug 25, 2022 10:45 PM
tnt10
Aug 10, 2018 04:26 PM
Philly Single
Feb 12, 2017 05:26 PM
