E-Pace 2018 - Onwards
Low battery indication
Old Jan 2, 2022 | 05:06 AM
Hinton4G's Avatar
Default Low battery indication
Hi there
I keep getting a low battery indication on the dash even after a long run.
It reaches a point where the rear won't open on its own, without manually lifting it open.
My battery charger when connected to the battery only takes about 15 minutes before it indicates that the battery is fully charged.
Any help/ideas would be very welcome!
Many thanks
Hinton4G
Old Jan 23, 2022 | 04:24 PM
Monkey2018's Avatar
Default Same here
I was told I need a new battery
Originally Posted by Hinton4G
Hi there
Many thanks
Hinton4G
Old Jan 23, 2022 | 07:02 PM
2018XF25T's Avatar
Here in the states, any auto parts stores that sells car batteries can test your car's battery FREE of charge. I think your battery is showing that it is on it's way out. Have it check before you buy a new one. Also, check battery connections if loose or corroded. Tighten or clean battery cables & + - post. Good luck
Old Jan 29, 2022 | 04:36 PM
dagny747's Avatar
Default Low Mileage?
2018 epace: my wife drives very few miles. She had her battery replaced under warranty December 2020. Basically lack of use no codes or unusual draws, loose wires, etc
Old Jan 29, 2022 | 06:26 PM
2018XF25T's Avatar
Wow in 2 years battery needs replacement? You can use a battery charger if the car is not in use for a week or so that way battery is always charge to spec. A lot of the members here use CTEK battery charger on their Jaguars.
Old Jan 30, 2022 | 04:23 AM
dagny747's Avatar
Normally I would, in fact I have one in my garage, along with a battery pack left over from my XJ6L. However, due to an accident and being in a wheelchair I can no longer do that. I do use the remote start and the app to keep track of her mileage to ensure the vehicle is running. Not optimal but it’s better than nothing. Now if I could drive it around the block remotely 😉
Old Feb 1, 2022 | 08:30 AM
Hinton4G's Avatar
Hi Monkey 2018
Thanks for your reply. I thought the same as you as well. But I took it to a technician who connected what looked like a small laptop. He then re programmed the battery charge monitor. This made the car think it had a new battery, and all has been well since then.
Fingers crossed !! A main dealer would be able to do the same.
Regards
Old Feb 1, 2022 | 08:35 AM
Hinton4G's Avatar
Hi 2018XF25T
Thanks for your reply. A technician re programmed the battery condition monitor, and all has been ok since then.
Regards
Old Feb 1, 2022 | 08:39 AM
Hinton4G's Avatar
Hi 1997XJ6L
Thanks for your reply. A technician re programmed the battery condition monition, and all has been ok since then.
Regards
UltraPeepi
Feb 23, 2026 08:34 PM
Spyderturbo007
Jul 7, 2021 01:30 PM
Cbrooen
Sep 9, 2020 08:41 AM
Jagstefano
Dec 26, 2018 04:25 AM
Vancouver777
Mar 12, 2016 02:04 PM
