E type ( XK-E ) 1961 - 1975
16” vs 15” Steering Wheel….
Old Jan 21, 2026 | 06:00 PM
mpawelek's Avatar
Default 16” vs 15” Steering Wheel….
I am used to squeezing under the steering wheel in my ‘64 356 SC but wonder if the 1” difference in the aftermarket steering wheels for the XKE make a difference in sliding into the seat? Because of the lowered floor it takes a contortionist. 😀
Old Jan 22, 2026 | 10:50 AM
Bob_S's Avatar
I have no personal experience, But I have been told that it makes it much easier to get in and out of the XKE. Now it may also increase the steering efforts slightly due to the smaller diameter.
Old Jan 22, 2026 | 11:56 AM
mpawelek's Avatar
Thanks Bob. No worries about steering effort. The power steering on my Type 2 can be turned with one finger. It’s amazing.
Old Jan 22, 2026 | 12:07 PM
Valerie Stabenow's Avatar
Default Your Series 2
If you are considering buying a new steering wheel, it may be worth looking at the height of your seat cushion. Some owners have lowered the foam by taking a slice off the bottom. The steering column also has telescoping capabilities which may allow some additional movement.
Old Jan 22, 2026 | 12:34 PM
OCDHerb's Avatar
Did you know that in addition to being able to adjust the steering wheel fore and aft you can also raise it up and down. There is a bolt under the steering column that can be loosened and allows the steering column height to be adjusted. I'd send you a picture but my car is getting final detailing.
Herb
Old Jan 22, 2026 | 02:34 PM
mpawelek's Avatar
Did not know that. Thank!
ftypedreams
Nov 22, 2025 04:05 PM
Atipical
May 27, 2024 04:42 PM
Wayne Lea
Jan 15, 2022 06:14 AM
carzaddict
Aug 24, 2016 03:35 PM
