E type ( XK-E ) 1961 - 1975
Carburator Problem
Old Apr 27, 2022 | 10:41 PM
falderfer's Avatar
Default Carburator Problem
Recently my 1970 Jaguar Series 2 has developed a carburetor problem. I assume that one of the jets in one of my carburetors is stuck. It began idling at 20,000 RPM's. I am hoping I don't have to have the carburetors rebuilt. Does anyone know of an easy fix for this situation such as something that could added to the gas tank? At first I thought the choke was stuck but that's not the problem. Recently the RPM's are increasing up to 30,000 RPM's . Any thoughts?
Old Apr 28, 2022 | 04:37 AM
dibbyandco's Avatar
I assume you mean 2,000 and 3,000 rpm! Before you start taking the carbs apart, I'd look at the linkages to see if they are sticking. Work your way from the bulkhead all the way down to the carbs. Can you manually reduce the revs at tickover to normal levels by tweaking the linkages?
Old Apr 28, 2022 | 01:47 PM
falderfer's Avatar
No, meant 20,000 initially and now it has increases to 30,009
Old Apr 29, 2022 | 03:34 AM
dibbyandco's Avatar
Don't mean to be picky, but it can't be 20,000 and 30,000. You wouldn't have an engine. The red line ends at 6,000 for a series 2 4.2 litre, with no revs indicated past that number. Nonetheless, I think your point is that the revs are sticking at too high a level. Have you tried manually moving the linkages under the bonnet at tickover as I suggested above?
Old Apr 30, 2022 | 05:18 AM
falderfer's Avatar
Thank you for your advice, that's exactly what the problem was. Apparently an adjustment screw for idling had moved and caused the problem.
robert22225
XK120 XK140 XK150
May 18, 2018 02:26 PM
ejjbee
Apr 27, 2016 03:31 PM
4jagspeter
Mar 17, 2016 01:15 PM
Holein1
May 26, 2012 08:31 AM
