E type ( XK-E ) 1961 - 1975
Cylinder head dimension
Old Sep 10, 2018 | 08:56 AM
EricStone's Avatar
Default Cylinder head dimension
Hi all - I am restoring a series 3 that has had the engine swapped out for a later one with, I assume, the machined out head at the exhaust valves(Sort of part hemi) The engine high compression number 7P50617SB. I have been unable to find the specs for this motor. I assume that the head is not the standard flat-head dimension as I have fitted the 6 Weber downdraft conversion and now the bonnet does not close. It should as the conversion was designed for this. I can only assume the head is taller. Take a look at the pics and if anyone could give me comparative measurements I would appreciate it. As yet I still haven't been able to get the engine to run properly. I'm fitting smaller jets as the supplied ones ran far too rich. Another reason for thinking the head is different. If this is the case am I right that the static timing is to be set at 0 BTDC and not the normal 12 BTDC
All advice/Help appreciated
Eric
Head 140mm tall
Tappet Cover to top 110mm
Set-Up
25 mm high
Height including inlet 165mm
EricStone
Sep 6, 2018 10:23 AM
Matt300ZXT
Mar 24, 2013 06:25 PM
tassa85
Jul 30, 2011 03:13 AM
michaem101
Jun 26, 2010 11:53 AM
