E type ( XK-E ) 1961 - 1975
Failed Headlight Bulbs (Both)
Old Apr 20, 2024 | 01:41 PM
66Jaguar's Avatar
Default Failed Headlight Bulbs (Both)
I have experienced a very strange failure on my 1966 E-Type OTS. For over 2 years, I have had the headlight low-beam filaments fail while driving at night. Here is what happens: I am driving along and for just a second, both low-beam bulbs suddenly get noticeably brighter and then...darkness (no light output from either bulb). I then use the dip switch to change to the high-beam filaments and then have enough light to drive home. When I change the headlight bulbs, everything works as it should. I have replaced at least 4 sets of headlight bulbs to date. Most recently, I replaced the headlight switch on the dash. I am hopeful that someone has the solution to my car's frustrating problem.
Old Apr 20, 2024 | 07:12 PM
lrgridley's Avatar
Sounds like it might be due to a voltage spike from a bad regulator. Do the dash lights brighten too when that happens? I'm not generally a fan of the "spray and pray" school of fixing things but you might try a new voltage regulator.
Old Apr 21, 2024 | 12:02 PM
billb44's Avatar
Might be the regulator as mentioned but when it fails the voltage should change slowly. I would be suspicious of a loose connection at the battery. If that disconnects the voltage will spike quickly, especially if the alternator revs are high like when driving at speed. Check both terminals.
Old Apr 22, 2024 | 11:02 AM
66Jaguar's Avatar
I have ordered a new "control box" (voltage regulator). When it arrives, it is an easy swap. I gonna cross my fingers for good luck! Thanks!
Old Apr 22, 2024 | 11:04 AM
66Jaguar's Avatar
Thanks for the idea. I will first change the voltage regulator ("control box") when it arrives this week. I will also check the terminal connections.
Skforza
Mar 2, 2021 01:20 PM
VancouverXJ6
Nov 29, 2020 11:09 PM
magnum454
Apr 24, 2015 12:21 PM
mannymux
Jun 17, 2012 07:07 PM
dumblecollie
Nov 11, 2009 11:51 PM
