E type ( XK-E ) 1961 - 1975
Header Tank Overflow while starting Engine
Old Jul 3, 2019 | 05:08 PM
jerjag65's Avatar
Default Header Tank Overflow while starting Engine
1965 E-Type - While cranking engine, before it starts, the header tank will over pressurize and start to release fluid through the overflow. Never seen this before. Ideas?
Old Jul 4, 2019 | 07:41 AM
Bob_S's Avatar
Hi Jerjag64,
Sorry to hear about your trouble. Does it stop over pressurizing the header tank when it warm-up? Or haven't you let it run that long? Is there any milky white oil on the dipstick? Does the exhaust look white and have sweet smelling to it? (I assume your are using ethylene glycol for antifreeze - it tastes and smells sweet. It's also toxic.)
My first guess is a head gasket leak from the cylinder to the cooling system. I have been told, never tried them, that a good auto parts store sells strip of paper that would detect exhaust gasses in the coolant, I believe it is or like litmus paper.
You you could try re-torque the head and adding some bars leak. I personally don't like using bar leak or other radiator sealers.
Old Jul 4, 2019 | 01:05 PM
jerjag65's Avatar
Originally Posted by Bob_S
Hi Jerjag64,
Thank you for your response. This is happening as I cranked the engine to start. I didn't actually allowed the engine to start after seeing this happen. Oil does look fine and there is no white residue on the header cap. I'll look into the "test papers" and try again this weekend. Thanks again Bob!
Old Jul 6, 2019 | 04:44 AM
abowie's Avatar
Blown head gasket.
gmsclassics
Aug 8, 2013 08:19 AM
Prescot
May 27, 2013 12:21 PM
Derek1
Feb 27, 2013 09:17 PM
shaz1990
Oct 15, 2011 09:22 AM
timfountain
Jun 8, 2009 05:33 PM
