Headlamp Question
I switched my '67 with open headlamps to closed. I know that the sugar scoops are different but will the buckets from my mid '67 car work with the closed headlamps?
Herb
Herb
So, irritating as it may be, my answer is that you should select your lights and then determine how to accommodate them.
I did not care about looking as original and also wanted to delete the signal light 'pods' under the bumper.
I believe the buckets are essentially the same except one difference. The covered headlight buckets have a bevel on the bottom to clear the front tires. I don’t know if you really need that but you want them if you’re going for an accurate aesthetic.
