E type ( XK-E ) 1961 - 1975
Help with part description/number
Old Feb 23, 2022 | 06:05 PM
Valerie Stabenow's Avatar
Default Help with part description/number
Trying to figure out what the little rubber shields are that are attached to riveted strips in the engine bay of my 69 S2 coupe are called and if possible the part number.
They are riveted to the cross member just in front of the heater box unit. In the photo you can see the rubber just to left and right of the heater fan unit. They are meant to seal that area from tire splash. thank you!
Old Feb 23, 2022 | 08:54 PM
lrgridley's Avatar
That's a "Mud Shield Rubber" I believe part number BD20434. As I recall Moss sells you a roll of it and you cut the lengths to fit, including punching holes for the rivets. If you have them, best to save the old ones to use as templates.
Old Feb 23, 2022 | 09:29 PM
Default Thank you!
Yes, that's it exactly. The metal strips are in tough shape, so using that part number, I found the kit to replace all. Thank you!
adenshillito
Jul 13, 2021 06:40 PM
alanroberts50
Jun 29, 2020 09:50 AM
reko19
Nov 25, 2017 07:44 AM
tedwone
May 24, 2017 12:32 AM
CarSmartNot
Nov 20, 2009 09:26 PM
