E type ( XK-E ) 1961 - 1975
Instrument glass
Old Apr 27, 2026 | 12:47 PM
craft's Avatar
Default Instrument glass
What is involved in cleaning inside of instrument glass on a Series II E-Type? Speedo and tach are fine, just the smaller gauges are fogged up.
Old Apr 27, 2026 | 01:12 PM
Valerie Stabenow's Avatar
Default Access from the back of the cluster panel
Not much to cleaning these, do disconnect the battery as a precaution.
Take photo of how wires/connections are made to the back of the gauge. Rotate the little thumb nuts to loosen the U bracket holding the gauge. Press from the back, pull from the front to bring the gauge out. There are little tabs holding the gauge ring trim. You can rotate that as explained here:
https://forums.jag-lovers.com/t/1970...-repair/356946
Carefully separate. You can use denatured alcohol to clean the glass, then do a final wipe with a good quality glass spray/cleaner. Reassemble, reinstall, reconnect, test.
Old Apr 27, 2026 | 02:12 PM
craft's Avatar
Thanks Valeria...now I know what Iam doing next weekend.,
Old Apr 28, 2026 | 05:55 AM
lbc3's Avatar
In theory, not much to it (Valerie makes everything sound easy), but if you have plumber's hands like me, I would suggest you acquire a set of replacement rubber o-rings, aka "instrument lens seal kit". If original, yours will be dry and fragile, and given that the instruments are fogged, it implies they have failed anyway. I think it's about $25, but by snail mail. So while you are waiting, you might consider sanding and painting your bezels. And if your clock doesn't work, we have a member, Michael Eck, who converts the original to electric, and it comes back with new seals looking brand new.
Old Apr 28, 2026 | 10:54 AM
Default One source for the seals
https://mossmotors.com/30-1252-instr...obyFaBhSowLMCs
Old Apr 28, 2026 | 11:34 AM
craft's Avatar
Thanks for the input and the source. I will let you know how it goes.
dadspet
E type ( XK-E )
Aug 5, 2024 05:10 PM
gailsluck
Feb 6, 2019 08:40 PM
EcbJag
Dec 20, 2018 11:49 AM
scatcat
Feb 20, 2017 02:09 PM
e21pilot
Jul 5, 2014 12:19 PM
