E type ( XK-E ) 1961 - 1975
loose post
Old Mar 18, 2015 | 12:32 PM
alfred's Avatar
Default loose post
After replacing points and condenser, I noticed that the post holding the points in place has become loose. This is messing up the gap and points are not always closing. The usual suppliers do no seem to carry the base plate anymore. Other than removal and attempting a repair, does anyone know where base plates might be found?
(1968 2+2 Series 1 1/2)
Thanks, Alfred
Old Mar 21, 2015 | 02:26 PM
Fraser Mitchell's Avatar
Essentially, you just replace the whole contact set.
This supplier is reliable as far as I know. There may be others of course, but the price is low enough not to be worth searching for the last 1% !
SNG Barratt - The Ultimate Jaguar Parts Specialist
The post is riveted on as I remember, so you could try to re-secure it with a punch and hammer, but frankly is it worth it when you can buy new for so little money ?
Old Mar 21, 2015 | 03:33 PM
retromotors's Avatar
Fraser,
As the OP pointed out, the contact set doesn't include the points pivot shaft. That looks to be part of either #13 or #14 in Barratt's catalog illustration (since the parts description cleverly does not reference the illustration number, good luck guessing which!)
In any event, it appears neither of those parts is available "online", by which I'm guessing means "not at all".
Regards,
Retro
ps .... Alfred,
Unless you are really hung up on originality, now would be a good time to pitch all that for a quality electronic ignition system.
Lo and behold, there's even one on the Barratt's page!
Old Mar 21, 2015 | 08:14 PM
alfred's Avatar
Yeh, switching to electronic ig. is an option. After I beat this chest infection I'll head out into the shop and see in the post can be TIG'd back tight. When I talked to XKs Unlimited they said they might get some base plates back in stock in two months.
Old Mar 22, 2015 | 08:04 AM
Sorry, forgot that the contact set is separate. My memory must be fading bad ! Probably a MIG weld underneath, followed by grinding smooth will fix it. Or spend the money for electronic ignition.
clubairth1
30
Sep 3, 2025 04:38 PM
GordoCatCar
Jan 2, 2017 01:10 PM
AtholC
Sep 9, 2015 09:07 PM
AL NZ
Sep 4, 2015 08:39 PM
