New member with a couple of questions
Hey all, I joined to get some info about getting my girlfriend's 73 v12 convertible running. I've gone through a lot of the threads and learned a ton, but I have questions about the fuel pump. Am I correct in thinking that the fuel pump should turn on when you turn the key on? The pump doesn't seem to do anything when you turn the car on, no hum, buzz, vibration or anything.
I also haven't been able to locate a fuse or relay for it.
I was hoping to be able to use the pump to remove the 25 year old gas from the tank.
As a plan B, is tank removal a big deal? It seems like it should come out from the top.
Any info would be appreciated, thanks.
If when you bump the pump, it starts ticking and then stops, its a sign that the pump needs to be removed and serviced.
You will find the fuse behind the cluster of gauges in the centre of the dash panel. If you look under the top padded section of the dash board, and just above the gauges you will see a retaining knob at the top left and top right corner of the instrument panel. Unscrew these and the instrument panel will swivel down via hinges at the bottom of the instrument panel.
The best way to drain and clean the tank is with the tank out. However, there is a drain plug at the outside, bottom of the pump that can be used to empty the tank. A reasonable job of cleaning the tank can be made by dumping fuel into the tank with the drain plug removed and a container to catch the fuel. The dumping of the fuel into the tanks tends to stir up any sediment that may be in the bottom of the tank. You can also remove the plate on the top of the tank were the fuel delivery and return pipes are located. This will gain you access to the inside of the tank. If you remove this plate, the gasket between it and the tank will have to be replace.
Regards,
Bill
edoz - welcome to the forum, when you have a moment, stop by the new member section and post an intro:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
WinterJag
16
Oct 9, 2015 07:49 PM
KarimPA
Sep 3, 2015 07:32 PM
