E type ( XK-E ) 1961 - 1975
Rear end rebuild
Old Nov 24, 2024 | 09:01 PM
Doss's Avatar
Default Rear end rebuild
Aloha,about to remove and rebuild. Have no idea what I am looking at parts to source or where to find them. Don’t know any torque specs or what book to find that will tell me. Any advice will be appreciated. Thanks Doss
Old Nov 25, 2024 | 07:04 AM
Daytona's Avatar
Hi Doss, and welcome to the forum.
You will find a wealth of knowledge here, but we need a bit more help from you. What year and model Jaguar are we talking about? But regardless of year and model, there are some good sources for parts.
https://www.sngbarratt.com/English(US)/#/uk/home .
https://mossmotors.com .
https://www.terrysjag.com .
And there is always Ebay, and Hemming's motor news.
Good luck.
Old Nov 25, 2024 | 07:14 AM
Fraser Mitchell's Avatar
It is most of a Jaguar rear independent suspension unit, but not mounted on the Jaguar subframe, or using the Jaguar radius arms.
So what car is it attached to ?
Old Nov 25, 2024 | 09:11 AM
DaveAllen's Avatar
1st pic shows the brakes are the separate cylinder type used on Series 1, hub carriers look consistent with Series 1 also. Maybe use Series 1 torque values / procedures for the wishbones, driveshafts, etc.? As already noted, its a custom framework supporting the rear end and custom radius arms, so removal and refurbishment of the custom parts might need a bit of guesswork.
E-Type Haynes manual is a decent resource.
HTH, Dave
Old Nov 25, 2024 | 04:06 PM
Valerie Stabenow's Avatar
Default part of an e type
Some of what's there looks like E type, but those 'braces' adjacent to the mufflers (first photo) are not part of any E type I'm aware of. The cross brace in the second photo doesn't look familiar either.
Link to really good info and photos/diagrams: https://newhillgarage.com/2021/12/26...ar-suspension/
here's a link to removal :
It looks like someone used an e type rear end in some kind of dragstrip car? racer? Will be interesting to learn what it is in!
Old Dec 9, 2024 | 12:08 AM
Doss's Avatar
Default Thanks
Thanks for your help, I finally filled out my info. It is in a 32 ford fordor built in the seventies. Aloha Doss
Old Dec 9, 2024 | 12:11 AM
Doss's Avatar
1932 ford fordor
Old May 14, 2025 | 02:19 AM
Doss's Avatar
i have the rear end out and on the ground. the parts we think are needed:
1. left and right rear hub seals inner and outer
2. left and right rear hub bearings inner and outer
3. two rear brake caliper rebuild kits (Dunlap)
4. rear caliper pads
5. two rear parking brake return springs
6. four coil over rear shocks (not too stiff)
7. lower control arm bushings
8. sway bar links
a list of possible sources would be of great help.
i will respond quickly to comments or questions
Aloha and Thanks, Doss
Old May 14, 2025 | 08:10 AM
johnrmclean's Avatar
Doing a 70 IRS myself now and searching for all the parts for a complete rebuild your probably going to find SNG the best for one stop shopping. Also If the order is over $100 they usually do not charge shipping while every one else's shipping is hefty in my opinion. Note that Moss and SNG, and a few others, have been bought out by an investment firm so part prices themselves are pretty much the same except for occasional sales. Welsh Jaguar in Ohio is a good source for salvage parts as they part out many vehicles and have knowledgeable staff while RWAutoClassics .com on the west coast posts a lot of salvaged parts on EBAY. Lastly I understand there is a lot of info on the Cobra car forums as many people convert Jag rear ends for those cars. Best of Luck!
2015 XJR L
Feb 5, 2023 09:44 PM
yzteee
Nov 23, 2021 08:29 PM
bic_bicknell
Jul 29, 2021 09:59 PM
Hashim_B
Jan 26, 2021 09:12 AM
Luke2004xjr
Exterior
May 31, 2020 11:05 PM
