E type ( XK-E ) 1961 - 1975
reassemble subframe
Old May 3, 2021 | 03:51 PM
Marley's Avatar
Default reassemble subframe
looking to find out what sealant is used when reattaching subframe to fire wall on a 69 OTS. when removed the bolts from firewall there was a black material around threads.
Old May 4, 2021 | 06:37 AM
Daytona's Avatar
Hi Marley,
Are you sure the subframes have not been removed and reinstalled before? Was black material on the threads, or on the flat bracket surface?
When I removed the subframe on my 68 FHC there was no evidence of any sealant, and I am sure the frames had not been removed before by a previous owner.
Good luck with the search and the task ahead.
Bill.
Old May 4, 2021 | 09:54 AM
Marley's Avatar
thanks Bill,I'm pretty sure it has never been removed. the bolts on the front end were all painted and the car had original paint thru out. I spoke to Chuck at Monocoque Metalworks and he felt you should protect the bolt holes from possible water getting between the plates on the frame and the firewall but did not know what the factory did.
Old May 4, 2021 | 11:16 AM
Daytona's Avatar
I am not sure if anti-seize compounds are water proof and/or non-permeable. So if there is supposed to be some type of compound to seal the threads, I would do a search on Loc-Tite thread compounds, or maybe just go to a Fastenall store near you and see what they have as a thread sealant. In my case we used anti-seize on the threads.
Bill.
Old May 10, 2021 | 05:02 AM
JerryCRM's Avatar
For what it’s worth, I restored a series3 in original condition. There was no sealant in or around those bulkhead bolts. Cheers
Old Jun 24, 2021 | 08:17 PM
vickxxx's Avatar
I had to replace the subframe on my 68 S 1 1/2 coupe and there was no sealant between the subframe and body when removing the old subrame.
Asdrewq
Mar 14, 2020 08:39 AM
Rudy Mensink
Nov 2, 2019 03:06 AM
brinny
Jul 31, 2017 01:26 PM
theJPster
Mar 19, 2013 05:17 AM
