E type ( XK-E ) 1961 - 1975
SIII Exhaust Tip 2 of 4 not used
Old Apr 18, 2017 | 10:42 PM
srpope80's Avatar
Default SIII Exhaust Tip 2 of 4 not used
This may be a weird question, but on any of SIII V12 owners with original exhaust and tips, are all 4 ports used and have "soot" in them?
Mine does not, only the 2 middle ports are used. Not sure what would cause this. I also have a whistle at high acceleration.
Pic:
Old Apr 25, 2017 | 11:20 PM
lrgridley's Avatar
Jaguar went from four exhaust outlets to two in 1974. The earlier four outlet exhausts had a muffler with four actual outlets so all four openings would emit exhaust gasses. I suspect you may have a later, two outlet muffler hence only the inner two are actually connected to the exhaust. If your car is a '74 the four fantail exhaust is not correct for your car. If you have a pre-'74 then it's likely at some point an incorrect rear muffler was installed.
Old Jan 25, 2018 | 08:33 AM
Gerry Golla's Avatar
Default Soot in only 2
I'm not sure when this was posted, but I just went and looked at my E.
The 2 outlet tip will not fit the 4 outlet muffler or the other way around, so this is very weird.
I have a 2 outlet that I no longer need
In fact I'm trying to find a 4 outlet tip.
Anyone out there have one?
Old Feb 1, 2018 | 04:18 PM
SNG Barratt USA's Avatar
Former Sponsor
https://www.sngbarratt.com/us/#!/Eng...R%204%20OUTLET
