sleving brakes
I also going to sleeve all the brake components. I found a place called Karps. Karpspb.com/sleeving.htm. Has anyone used them and if so what were they like. Also do any of u have a place to suggest.
thanks
nick
thanks
nick
Here you are: -
SNG Barratt - The Ultimate Jaguar Parts Specialist
There may be other suppliers out there with the same parts cheaper, but these guys know their stuff. Why try to save money on something your life depends on.
Only the bores of the Brake Master Cylinder and the Servo Cylinder may need to be sleeved. Unlike the Brake Master and Servo Cylinders, the seals of the Calipers run on the surface of the Caliper Pistons, not the bore.
Regards,
Brent
Welsh has them, good wiality, fronts are 105 per caliper didn't look at rears this am
Jaguar Forums Editor
Jaguar Press release
Sep 20, 2016 10:58 AM
