E type ( XK-E ) 1961 - 1975
Studs for 1964 E-Type 3.8 engine
Old May 28, 2022 | 04:35 AM
No Quarter's Avatar
Default Studs for 1964 E-Type 3.8 engine
Currently rebuilding such an engine, an unfortunately it's not a virgin, somebody has been in it before without proper knowledge. The studs on the engine are 13 short ones and 1 longer. One was installed upside down. So I need 3 more of the long ones, for the engine hoist brackets, rows 2 and 6? But my parts guy's webpage also talk about a an alignment dowel, where should that go?
Old May 28, 2022 | 03:08 PM
David84XJ6's Avatar
See notes on studs and cylinder head install
Rgds
David
File Type: docx
Old May 28, 2022 | 11:02 PM
No Quarter's Avatar
Rgds
David
Thanks, but it doesn't seem to apply to my engine. I only have studs that are threaded into the top of the block, so all 6"+something. The good text you had, is there something similar for my engine (RA75xx)
Old May 29, 2022 | 12:38 AM
No Quarter's Avatar
Actually, just got it solved.
Studs, yes the dovel stud was there, and in the right place. So I just need to buy 3 that has the extra length for the lifting eyes.
Old May 29, 2022 | 04:44 PM
Fraser Mitchell's Avatar
All engines were short stud until the 4.2 came along, then, at the 7L blocks, the studs were extended into the bottom of the engine via the coolant jacket. This is when all the trouble started with block cracking etc. One of the short studs is a dowel-stud, and you've found this. As I remember it goes at the rear of the engine, but I cant remember whether left or right stud.
Lycaon
Feb 27, 2023 12:11 PM
340
General Tech Help
Apr 10, 2020 11:46 AM
71JagXKE
E type ( XK-E )
May 23, 2019 05:43 AM
Bd Tiger
Jul 24, 2017 04:14 AM
Jagrick
E type ( XK-E )
Feb 12, 2015 04:12 PM
