E type ( XK-E ) 1961 - 1975
toe in
Old Mar 21, 2018 | 09:48 AM
billb44's Avatar
Default toe in
After replacing ball joints and checking steering play, I have checked the toe in crudely, but I think accurately enough, and find it needs adjustment. Later, I will have it adjusted by a well equipped alignment shop.
The nominal toe in is given as +3/32". I want to check my understanding. I believe that means the front of the wheel rim is in from nominal by 3/32" while the rear is out by the same amount. So the difference is 3/16" per wheel and if measured from one wheel to the other, the difference is 3/8". Is that correct or am I off by a factor of 2 or 4?
Greg in France
Jun 7, 2016 05:41 AM
Tijoe
Dec 18, 2012 08:21 PM
Bacardi 151
Oct 18, 2011 07:30 AM
Dimension247
Sep 22, 2011 09:16 PM
Ian H
Nov 3, 2010 08:13 AM
