E type ( XK-E ) 1961 - 1975
turn signal & speedometer bulbs
Old Jan 21, 2021 | 08:50 PM
Smonop's Avatar
Default turn signal & speedometer bulbs
In removing my DIP switch which was getting inconsistent (the new one is the wrong one - frustrating...) I nudged the turn signal relay. I replaced the relay but now only the right turn signal works, the left, nada. Is that a relay problem or a wiring issue?
I also noted that my speedometer bulbs were not functioning. I removed both, bench tested and they light up... difficult wiring trace?
Old Jan 22, 2021 | 11:58 AM
Smonop's Avatar
Ok, so I contorted myself and took another look this a.m. at the wiring under the dash left of the steering and found the issue that solved both the turn signal and speedometer bulb issue.... the connection circled in yellow had disconnected, likely as I was futzing around trying to replace the DIP switch.... all is once again right with the world, today anyway.... this hour... minute... Happy Motoring....
Old Jan 22, 2021 | 05:38 PM
Fraser Mitchell's Avatar
Nice to know you were able to sort it out without spending money !
jag68
Oct 21, 2019 06:57 PM
Camerenxj6
Oct 4, 2018 04:53 PM
95Leaper
Sep 1, 2016 01:38 PM
gragner66
Oct 12, 2012 05:57 PM
Afflict
Jul 30, 2010 12:48 AM
