E type ( XK-E ) 1961 - 1975
XKE 1969 Series 2,bulb issue
Old Mar 18, 2020 | 09:07 AM
Terry S Martin's Avatar
Default XKE 1969 Series 2,bulb issue
I have managed to get nearly all the indicator lights working on my Jag. However the brightness of the bulbs seems low.
the head light indicator (blue) is almost unseeable. The only light that is bright is the Hazard warning light.
can any body throw some light on this issue.
the battery is fully charged and the alternator is giving 13.5 volts.
the measurement at the some bulb holders is as low as 10.5 volts
Old Mar 18, 2020 | 11:44 AM
billb44's Avatar
You obviously have a volt meter, good. I suggest you probe one of the dim lights (10.5v) and determine whether the high side is too low or the ground side too high. Measure each lead relative to the battery ground terminal. If the power is low suspect the head light or side light switch and connections. If the ground side is high check that the instrument panel is well grounded. Good luck.
Old Mar 18, 2020 | 01:32 PM
Fraser Mitchell's Avatar
After a while, the glass of the bulbs tends to get dark from dirt. It would be best if you replaced all the bulbs that are dim. Also carefully clean the little coloured lenses the bulb shines through on both sides.
Old Mar 18, 2020 | 03:32 PM
Thanks for the tips, I could not find a local source for the threaded bulbs, I guess I will buy them through XKS
thanks again,
Terry
Geofflvmyjag
Jun 10, 2015 02:11 AM
anziobridgehead
General Tech Help
Jun 15, 2013 10:57 AM
robhair
XJ40 ( XJ81 )
Apr 19, 2012 05:06 AM
Dollajaaag
Jan 18, 2011 01:21 PM
tgregory13
Dec 7, 2008 07:31 AM
