Exterior Talk about your rims, bodykits, and other exterior mods here.
lug patterns
Old Apr 25, 2009 | 02:25 AM
cpalmer's Avatar
Default lug patterns
does anybody know what other cars have the same lug patter as a 94 xj6.
Old Apr 25, 2009 | 08:26 AM
Thermo's Avatar
Veteran: Navy
cpalmer, your car has a 5-475 bolt pattern. All of the XJ's (XJ6, XJ12, XJR) will have this same bolt pattern. Doing some looking on http://www.tirerack.com, as long as you stick with the XJ series vehicles, you can use the wheels up to atleast 2003, if not newer. Going with rims off of say an X/S-Type is not an option as they use a different bolt pattern.
One word of caution though, if you go with a different body style, check the backspacing of the rims to make sure that it is compatible with your vehicle.
Old Apr 26, 2009 | 09:12 AM
cpalmer's Avatar
okay thanks! i was hoping that infiniti or somethign would have the same bolt pattern. its hard to find used jaguar rims offline. i wanted to put th g35 19's on it
Old Apr 30, 2009 | 02:49 PM
Cadillac's Avatar
That's correct XJ
This is what I am using on my '93 XJ40 (1995-97 X300 wheels )
max224
Jun 21, 2024 12:17 PM
MrWhite
33
Oct 22, 2015 10:29 AM
tomkilner
Oct 9, 2015 07:10 AM
XJ8JR
Sep 29, 2015 06:59 PM
