F-Pace (X761) / C-X17 2016 - Onwards
2017 f-pace 2.0 front radar sensor blocked?
Old Jun 9, 2024 | 08:22 AM
jschicksps's Avatar
Default 2017 f-pace 2.0 front radar sensor blocked?
So my f-pace showes a warning front radar sensor blocked on the dash which shuts off the cruise and auto braking. I purchased this car with a busted grill looked like somone backed into it. The sensor was popped out of its bracket but no visible damage. I snapped it back in and everything worked with no grill. I now have a new grill (aftermarket) and I get the sensor blocked message?? I can’t believe the grill would make a difference so assume the sensor might be the issue? Any ideas? If I get a new or used sensor will it need calibrated or can I just swap it out! I am about 1 hr to the nearest dealer so hate to take it in just to be told it needs a sensor and then bring it back again…
Old Jun 9, 2024 | 12:47 PM
2018XF25T's Avatar
The sensor might had been compromized upon impact. My XF doesn't have a front sensor, but I have seen a lot of F-Pace that have it. Do you have an OBD2 scanner to see what the codes are?
Old Jun 9, 2024 | 01:46 PM
jschicksps's Avatar
Also I have a aftermarket grill would this have any effect? The center section of my grill was half missing when I got it, so I have no clue if it was all honeycomb or not but I see some of the grills have a rectangle which would be in front of the sensor? But my sensor is mounted in a bracket right in front of the a/c condenser about 3 inches behind the grill, it is not mounted to the grill? My new grill is all honeycomb.
Old Jun 10, 2024 | 12:02 PM
If it worked prior to fitting the grille I'd suspect the new one is causing the problem, go back and see if anything looks like it could be causing a problem.
Old Jun 14, 2024 | 06:05 PM
jschicksps's Avatar
Aftermarket grill was the issue!! As I have said many times, it’s not what you know but what you don’t know that will get you!! Got an oem grill and everything works!!
Old Oct 14, 2024 | 09:45 AM
svr_bg's Avatar
[QUOTE=jschicksps;2757896]So my f-pace showes a warning front radar sensor blocked on the dash which shuts off the cruise and auto braking. I purchased this car with a busted grill looked like somone backed into it. The sensor was popped out of its bracket but no visible damage. I snapped it back in and everything worked with no grill. I now have a new grill (aftermarket) and I get the sensor blocked message?? I can’t believe the grill would make a difference so assume the sensor might be the issue? Any ideas?
Hello , do you found some sollution? From 2 months , we try to calibrate . Without emblem is ok , when we put emblem and give " blocked sensor".
Old Oct 14, 2024 | 10:19 AM
@svr_bg
The solution is directly above your post, the aftermarket grille was the issue.
johnstacey
Jan 11, 2023 04:29 PM
MikeyB10
Jun 29, 2021 02:59 AM
Rubenspits
General Tech Help
May 14, 2021 01:31 PM
Ludovic Card
Jul 2, 2016 09:17 AM
Peperami
Mar 25, 2015 04:35 PM
